Old 4-Oct-2013, 11:33 PM   #2
It sounds as if your previous location (http://forum.tvfool.com/showthread.php?t=9384) came together well using an attic mount.
If the new attic turns out to have similar characteristics, you can use the same antenna as before, the RCA ANT-751R. If you have difficulty from inside the attic, test reception outdoors.
