Old 4-Oct-2013, 8:17 PM   #3
A Simple Reception Situation.
For Reliable Reception of Many Local Broadcast Tv stations/channels.
Install a ANT751 antenna above the roof roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South East , South , South West , East.
Aim the ANT751 antenna at about 156 degree magnetic compass direction.
Home Depot and Lowes will sometimes have the ANT751 antenna in stock in the store , no matter what the Home Depot and Lowes web sites say.
http://www.solidsignal.com.
http://www.amazon.com.
__________
No antenna system amplifier is required.
__________
__________
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and house.
Multi-path reflections signals bouncing all around.
Obstructing , impeding , blocking , Broadcast Tv Reception.
___
The Best Pratice is to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
_______________
