The San Diego market often requires a 'two-antenna' solution. In this case an RCA ANT-751 may work well enough. Alternately, consider the Antennas Direct Clear Stream 5. It was designed with H-VHF in mind but proved to have decent UHF performance.
I would opt for the two antenna option, an Antenna Direct DB4e, Antennacraft Y5713 and a UHF/VHF combiner. Face the UHF antenna at 140° then fine tune the aim from there. Point the H-VHF antenna at 205° as the starting aim point. I would not try to mount both on a satellite J-pole, it's not tall enough to allow for adequate separation, 3' minimum.
