Old 4-Oct-2013, 1:26 PM   #10
No static at all
No static at all's Avatar
I see your HD Stacker is for sale on Ebay. The FM6 is WAY too close to the TV antenna & may be compromising your FM reception.
Once the Stacker is removed, I suggest raising the rotor higher if possible & then put the FM6 5 feet above the rotor. The added height & removal of the Stacker may help clean up 101.5 & other stations you are trying to improve.
