Old 3-Oct-2013, 7:08 AM   #7
tvrick
Thank you all for the information and suggestions. Really appreciate the links and instruction!
I can forego both channels 2 (K02RB) and 3 on L-VHF. I'm not exactly sure what kind of content RTV and TUFF programming is (tried to look it up, something about manly content? haha) but I take it I won't be losing any on 2 because:
K02RB is a translator for KFLA-LD which should be receivable with a high-Band VHF antenna.
Even if I do lose it, it's one channel (so it looks like I can forego the low-VHF if that makes things easier).
A few questions:
1. If I get separate H-VHF and UHF antennas, can I place them next to one another or will that mess with signal?
3. Will I get better signal if I have separate H-VHF and UHF antennas? (Sounds like it from your previous comment GroundUrMast, but I'd just like to confirm. If the signal difference is slim, I would go with one unit not only because of aesthetics, but I'm not even sure how to connect the cable to the antenna so every splitter and extra step required is a potential hurdle, not that I don't enjoy a little bit of a challenge, though— I'm here after all chasing OTA!).
2. Just for my own knowledge, what is the difference between a H-VHF/UHF antenna and a L-VHF/H-VHF/UHF antenna? Smaller size?
