Old 2-Oct-2013, 6:46 PM   #6
Do NOT select a large all, channel antenna since there no low-VHF stations within range. Select either a large high-VHF/UHF antenna or a combo system consisting of separate UHF and high-VHF antennas.
I agree with everyone else, you need to mount outdoors, clear of obstructions. Indoor or attic mounting offers no realistic hope for success.
A large UHF antenna who's performance peaks around real CH-43 is needed for WPGH. The signals in the High-VHF band (real CH-7 through CH-13) are going to need a full size H-VHF antenna.
I would opt for an Antennas Direct 91XG, Antennacraft Y10713 and an RCA TVPRAMP1R. If WBPA were ever to come on the air with adaquate power and programing of interest, I'd deal with it using a cut for band L-VHF antenna which could be added into the existing system.
