Old 2-Oct-2013, 6:47 AM   #7
If you find you can't make the USB tuner work by improving the antenna aim or location, the SiliconDust HDHR3-US is worth looking at. It connects to the PC via Ethernet. This means you can locate the tuner close to the antenna if there is power and a CAT-5 wired connection to your LAN. (Wireless may work, but it's more prone to packet loss which will make the video and audio quality unacceptable.)
http://forum.tvfool.com/showthread.php?t=820
