Old 2-Oct-2013, 12:05 AM   #3
The largest group of Digital Tv stations channels is/are to the , North - North West.
You can Test reception with a Terk HDTVi antenna (not HDTVa) antenna in a window in the South East direction that has a smaller group of Digital Tv stations/channels and will most likely receive some of the , North-North West Digital Tv stations/channels also.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
_______________
The Tv Must Be Able to scan for the Digital Broadcast Tv channels , the ATSC Digital Broadcast Tv channels , aka , 8VSB Digital Broadcast Tv.
If the Tv is a older Analog Tv or is a type of Tv monitor with no Digital Broadcast Tv tuner.
Then.
Walmart sells a basic Digital to Analog tuner , the RCA DTA800B1 converter box.
______
Here are some converter boxes that do more.
http://www.epvision.com.
Channel Master has Digital Tuner boxes.
http://www.channelmasterstore.com
Last edited by teleview; 2-Oct-2013 at 12:57 AM. Reason: Clarify information and typos.
