Old 1-Oct-2013, 11:38 PM   #4
The point is to get the ANT751 antenna Up High.
More reasons for having the ANT751 antenna Up High.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on broadcast Tv reception with a Tv antenna and so do buildings and other obstructions including the roof and building.
The Best Pratice is to install a Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including the roof and building.
_______________
If you will like to Test reception with a indoor type antenna.
For your location , install a Terk HDTVi antenna (Not HDTVa) in/at a ~West~ facing window or balcony door window.
Also install a Winegard , LNA-100 'Boost' amplifier.
______________
Window glass and pelxi glass offer little resistance to the reception of Tv transmissions so it is Best to have the indoor antenna at a location that has the Best reception.
The following is a -Non Complete- list of building construction that will reduce Tv reception More.
Walls , metal siding , metal backed insulation , metal roofs , metal doors , metal screens on the windows and doors , concrete , concrete blocks , bricks , rocks , and etc. and more , reduce the reception even more.
