The , Tvfool Current Plus Pending Applications Included Digital Tv stations/channels map and channel list shows the the 2 main groups of Tv stations are to the , South and South East.
The 162 magnetic compas aim direction is a in between aim direction of the 2 main groups of stations.
Also with the antenna aimed at about 162 degrees magnetic compass direction , that puts the other receivable Tv stations/transmitters that are other directions at angles to the antenna.
Directional Tv antennas receive the the best at the front of the antenna and then to a lesser degree at the front angles to the directional antenna.
Then also to a lesser degree at the back angles and back of the directional antenna.
Directional antennas receive the Least amount of signal directly on the sides of the antenna.
So looking at where the Receivable Tv stations/transmitters are at and taking the directions/locations factors into concideration , 162 magnetic compass direction is a good starting aim direction to have the other Tv transmitters at angles to the antenna.
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
_____
Reason: Clarify information and typos.
