Old 1-Oct-2013, 8:25 PM   #6
Above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception to the , North East , East , South East , South.
Install the DB4e antenna aimed at about 172 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim the DB4e antenna.
__________
For Reliable and Dependable Reception , I strongly recommend install a factory made antenna.
Then you can 'Test' the construction and reception of DIY antennas , after you have Reliable and Dependable Reception with a high quality factory made antenna.
___
As always , trees and tree leaves , plants and plant leaves , in the directions of reception , have a Negative effect on broadcast Tv reception with a Tv antenna.
The Negative effects are and not limited to.
Multi-path reflections , Tv signals bouncing off the , trees , tree leaves , plants and plant leaves.
When the vegation moves with the wind , the result is moving multi-path reflections.
Moving multi-path reflections is/are Very Bad For Reception.
The Best Pratice is to install the DB4e or any other antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
_________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air channels' ~ 'Antenna Channel' in the Digital Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 12-Oct-2013 at 6:45 PM. Reason: Clarify information and typos.
