Old 1-Oct-2013, 5:22 PM   #6
mephiska
Originally Posted by teleview View Post
If ,
KNTV-DT , REAL VHF high band digital channel 12 , virtual number (11.1) NBC.
Is not received well , then install this 1 antenna solution.
Install a Antenna Craft HD850 all channel in places of the UHF antenna.
If the preamp is a all channel preamp and is in working condition , it should be Ok to use with the HD850 antenna.
Aim the HD850 antenna at about 162 degree magnetic compass direction.
I will like to know the make and model number of the preamp.
For the preamp to function , the power supply , power injector , preamp , need to be connected.
All three componets of the preamp unit can be on the input side of a splitter or use a splitter that will pass power through one or more of the input and output ports of the splitter , if the power supply and power injector are connected on the output of a splitter.
In other words , for the preamp unit that is out close to the antenna to function , the preamp unit must have power.
The preamp is a Winegard ANWI8700 Signal Amplifier. I can dig around for the power supply for it, I'm sure I have it somewhere.
I'll try things with just the 850 to start, and if I can't get enough channels I will try and add the 2nd antenna.
mephiska is offline   Reply With Quote
