Mount a ClearStream 2V aimed due west. Use a simple two-port splitter that is suitable for Cable TV service. If you are completely removing cable service, you can likely re-use the existing coax in the home. You do not need nor should you use any amplifiers.
You can pick up everything you need at Walmart or Best Buy.
