What's not to understand?
1) You have a defective pre-amp. Replace it. A properly functioning, properly selected pre-amp is mandatory for reception out of Memphis.
2) If you still have issues after replacing the amp as recommended and there is a tree right in the line of sight, fix that problem by either moving the antenna elsewhere or remove/trim the tree.
