Old 30-Sep-2013, 8:06 PM   #2
Install a Terk HDTVi antenna (not HDTVa antenna) in/at a West Facing window or West Facing patio/balcony door window.
Aim the antenna West.
Here is how to aim indoor and outdoor antennas.
A amplifier is not required.
For 1 Tv use No splitter.
For 2 Tv's use a simple common splitter.
If a Long continues length of coax is required to have the antenna in a West facing window / patio/balcony window , and then run through the room or rooms to get to the Tv , Then So Be It.
Window glass / pelxi glass , pass Tv signals Ok.
Other building constructions , such as walls and etc. have more reduction of signal strength.
For More Digital Tv stations/channels and Improved Reliable Reception install a ANT751 antenna above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , North West , West , South West.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Scan for Channels.
____________
http://www.solidsignal.com.
http://www.amazon.com.
___
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast tv reception and so do buildings and other obstructions including your own roof and house.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
_____
