Aluminum siding makes a indoor antenna an unlikely-to-be-successful proposition. Compounding that, your terrain analysis is poor and any signals that might make it to your home will be weak and scattered as your location is basically a hole in the ground with regard to the signals from Pittsburgh
Unless you are prepared to go to the rooftop and to go large (and I do mean LARGE), forget it.
