I presume the ABC affiliate you're having trouble with is KGO...  http://forum.tvfool.com/showthread.php?t=13689
As I recall, WMC asks for your ZIP code when you set it up. It seems to limit you to stations that it find's listed in the guide data retrieved using that ZIP code. Try changing the ZIP code to another that's closer to the station WMC is refusing to display.
