Old 29-Sep-2013, 4:48 PM   #6
KJac
First let me say if you are offended I apologize, I thought I was clear in all of my posts. I thought with a bigger antenna the reception and number of channels would increase it being placed outside and at twice the height.
1) The antenna I have is below as stated it is an HDB8x, sorry that I left off the HD from the model.
2) The Antenna Direct model I am not sure of it was given to me and I since trashed the box. But from pictures it is a C2 with a wire mesh on the back and tapered antenna on the front.
3) I donot have both antennas connected on the mast or combined. The HDB8x is outside on the mast and is a new install. The C2 is attached to garage door rail in the garage facing South.
I did a rescan each time I re-aimed the antenna.
Channels- 4.1,4.2,4.3,: 7.1,7.2,7.3,7.4; 13.1,13.2,.13.3, 28.1, 56.1
Solid Signal Xtreme Signal HDB8X High Definition Blade 8 Bay Xtreme Antenna VHF/UHF (HDB8X)
Ronard 124 Y-Wall Mount 24 Clearance (124)
Winegard HD6010 Omnidirectional FM Antenna (HD-6010)
Winegard AP8700 Chromstar 2000 Series VHF/UHF Pre Amplifier (AP-8700)
KJac is offline   Reply With Quote
