Old 29-Sep-2013, 5:30 AM   #3
phone man
Wow, you've got a great TVfool report. Lots of strong signals and all in the same direction. At first I thought you were lacking an NBC affiliate in Binghamton but a quick check shows channel 34 carries both ABC and NBC programming. You should be able to receive all channels in the green and yellow zones on your report easily with any small antenna rated for upper VHF and UHF frequencies.
Unless your house has a lot of metal in the walls I suspect you could also get by with small set top antennas for each TV. The main TV at or below ground level would be the only possible exception.
phone man is offline   Reply With Quote
