Old 29-Sep-2013, 12:32 AM   #2
The channels that you want are all UHF, so try an Antennas Direct DB4e in your attic.
The signal attenuation caused by the attic construction can vary; you just have to try it. The leaves might not be a problem; again, you must try it.
You might need to try different locations in the attic for best results.
