Old 28-Sep-2013, 9:17 PM   #1
JefB
Attic Antenna Advice
I'd like some advice on choosing an antenna to go in my attic. Here's my signal analysis:
http://www.tvfool.com/?option=com_wr...46ae6e22ecd402
I have fiberglass shingles and a big live oak tree and a big mango tree in the back yard on our NE side, but would really rather not place the antenna outside. I could place the antenna in the attic to line up with the V between the trees, but will still have some leaves to get through. From there it's clear across a small lake before hitting more trees and houses. We're not interested in the Spanish channels and I assume the 90 mile stations are not possible, so there are just the seven channels within 20 miles to the NE. I'll be attaching the cable to a Hauppage WinTV 2250 dual tv tuner. What antenna would you recommend I buy. Alternately, I see that there are several simple DIY plans around that I could build. Do they really work as well as mass produced antennas?
Thanks for your help,
Jeff
JefB is offline   Reply With Quote
