Old 28-Sep-2013, 10:04 PM   #1
jakkwb
Revisit old thread
I am revisiting this old thread I posted quite a while ago. I unhooked the antenna and took it down for a while (Netflix). Well, today I thought I would try it again. I put it back in the same spot, with an amp this time, and now I am not getting any channels to speak of, except 8-1,2 and 19-1thru4. Very frustrating....
I really want to get this working again. That monster was a beast to get mounted!
The power supply for the amp is pretty warm to the touch, if that means anything....
Here is the old thread starter:
Ok, here is my info:
http://www.tvfool.com/?option=com_wr...3e4738e0716755
I picked up a Channel master 3671 for pretty cheap over the weekend. I would like to be able to pick up the stations to the SE of me, in the Memphis area.
I can get the antenna at about 40ft or so to start with. I do have a large magnolia tree right in the path less than 30 ft away from where the antenna is to be mounted. Do I need to select a better location where this tree is not in the way?
Any suggestions? Do I need an amp? Also, I plan to attach 3 tvs, and a computer. What do I need to do that with?
Sorry, I don't know much about this...
jakkwb is offline   Reply With Quote
