Old 28-Sep-2013, 8:03 PM   #4
The Current Broadcast Tv stations/channels that are transmitted and received in,
USA , Canada , Mexico , are ,
UHF band channels 14 thru 51.
________________
WCES-DT Real VHF low band channel 06 , virtual number (20.1) PBS .
Is a Very Weak Signal of minus -2.0 NM(dB) and is 89.1 miles distant and 2 edge path obstructions of hills and mountains.
The low band Digital Tv channels 2 thru 6 are at a disadvantage for reception when the signals are very low signal strength because of natural and human made interference.
WCES channel 6 will most likely not be received reliably.
If you will like to inclued the reception of channel 6 , reliable or not.
Then I recommend use a Winegard HD7084P All channel antenna.
And a Winegard , LNA-200 'Boost' XT amplifier.
The HD7084P receives better then the HD8200U antenna.
Without the low band channels to receive , that leaves the VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
If you will like to receive VHF high band channels 7 thru 13 and UHF channels 14 thru 51.
For reception of channels 7 thru 51 install a Winegard HD7698P antenna aimed at about 327 degree magnetic compass direction , so as to concentrate reception on WMGT-DT Real UHF channel 40 NBC and MyNetwork.
Install a Winegard , LNA-200 'Boost' XT amplifier.
If WMGT , NBC is received , you 'Test' can turn the antenna more in the direction of W35BB Real Uhf channel 35 , http://tv.35.tv , to improve reception of W35BB without losing reception of WMGT , NBC.
http://www.com/tripods%200703/4712.html.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) , chimney antenna mount.
By the ronard antenna mounts at solidsignal by typing the word , ronard(x) in the solidsignal search box.
Buy the ronard antenna mounts at , http://www.solidsignal.com , or buy at http://www.ronard.com.
Here are some plaqces to buy antennas.
http://www.solidsignal.com.
http://www.amazon.com.
____________________
