Old 28-Sep-2013, 7:57 PM   #3
v99
I don't see any L-VHF (real CH-2 through CH-6) signals on your report that would suggest using the Winegard HD8200U.
I would use the HD7698P or the 'big guns', an Antennas Direct 91XG and an Antennacraft Y10713.
I would also be looking for a reasonable way to mount clear of trees. This may prove the most valuable 'investment' in your system.
Thanks for the response.
The pines in the area are very high. So going up would be impossible/cost-prohibitive.
But about 30 yards away from the cabin is a field. It isn't ours but a family friend's. I would think he would allow us to use a spot off to the side. But how far do you have to go into the field to get signal clearance from the trees? The direction of the signals would unfortunately be coming from the direction of the cabin (read: trees). Do people run 100 yards of cable in order to get a decent signal?
v99 is offline   Reply With Quote
