Need some help with an antenna for this rural Georgia location.
Here is my report
This is a weekend cabin. It sits about 4 feet up and has a metal roof. I'd like to mount the antenna on the gable so I would say the antenna will be 28-30 feet up (4ft crawl space, 20ft to peak, 5ft above metal roof. Ish). It's in the woods so there are a good many pines, especially in the direction of the channels. No major wind issues. There is currently no cable and won't get it, so we'd be willing to spend a few hundred on getting a decent antenna set up. The purpose is to watch football on the weekends when we are up there. There will be only 1 TV.
I guess I need a pretty strong antenna to be able to reach the channels around the 328 mark - we definitely want the basics: pbs, abc, cbs, and fox which are all around 57 miles away. Is the Winegard HD8200U strong enough? Would I need a pre-amp? Please recommend the best antenna. There are no physical size restrictions - we just want something that works!
If I wanted to try for nbc, any chance I could get it? It appears to be a very, very weak signal for my location (-1.9 boooooo. Is that - even a signal? LOL).
Anyway, I found some great info on here, particularly anything teleview posts. Also, this post on how to read the tvfool chart. Elmo wrote this in response to another poster and it's pure gold for a newbie!! Thanks to Elmo for this...
Originally Posted by elmo
Well, I'll tell you what you need to look at. First, check your chart, identify the channels you want. Make sure each has a positive value for the Signal NM - the higher the better your odds of tuning. Then you lump together the general directions of them all, which in your case, south pretty much covers it, with the exception of 24. Being that 24 is your best signal, I wouldn't work too hard to get it. The hope is that your antenna will be able to still pick it up even if you don't aim right at it. Now you look at the bottom tables that show if the signal is UHF, VHF-Hi or VHF-Lo. ...Not all antennas are designed for all frequencies, so you'll need to make sure yours will get UHF & VHF-Hi (down to Ch 7). Then you have to consider your installation site - trees being the biggest hurdle. You'll want to have as clear of a line of sight to the south. Unlike satellite which needs open sky above, horizon is the best for an antenna.
...Going beyond that, you'll start to see A/C indicators. So if you try to pull those signals beyond, you may get interference from the closer signals that are close or sharing the same Real channel. If you want to go a little bigger, maybe look at the Winegard HD7694p. The bigger the antenna, the better the range. You'll want to avoid too much range as you'll miss your sweet spot and start picking up stuff further south that could impact your closer signals. Again, that's where the A/C indicators on the left of the chart come into play. Think of it as you want to hear the conversation at your table in a noisy restaurant....not all the other chatter.
I appreciate all of your advice. Thanks!
