Old 28-Sep-2013, 6:30 AM   #25
Originally Posted by Damon459 View Post
I wanted to post a new "issue" to see if others have experienced this. I'm still using my RCA-ANT751 and RCA TVPRAMP 1R, and today I relocated my tv to the opposite side of my mobile home without moving the Antenna. Strangely enough my feeds are coming in stronger, not a lot strong but enough that the picture no longer pixilates. I'm still using the same cable and the same connectors, the only difference is the cable line now runs over the roof of my home to the opposite side and through the opposite wall. I'm curious if this is a common phenomenon?
Have you made certain that the coax connectors are secure. The symptoms make me suspect a poor shield connection in a connector.
