Old 27-Sep-2013, 11:19 PM   #1
KJac
Poor Reception New install
Help new install, Db8x 20 feet in the air, Wingard 8700 preamp.
Six ft. RG6/U from antenna to preamp, 25 ft. rg6/u from preamp to double grounding block( 1 FM antenna, 1 TV antenna , five ft. to preamp power, 4 splitter for to TV. Grounded from block to buried elec. service rod.
Tested with new 100ft RG6/u from splitter to 1 TV for signal strength/channel strength.
Equipment recommended by Solidsignal tech. Did have 1 TV in the garage hooked to Clearstream C2 mounted in the garage had hoped to increase channels by mounting outside. Y-mount outside two 10 ft poles.
http://www.tvfool.com/?option=com_wr...46ae5e15e0c773
KJac is offline   Reply With Quote
