Old 27-Sep-2013, 9:14 PM   #5
I never recommend a rotator with a antenna.
However this time I will.
Because of the Diverse Directions of the Tv stations and channels.
And the Low signal strengths of the Tv stations/channels
Install a Winegard HD7084P All channel antenna.
Install a AR40 antenna rotator and control unit , to turn the Large HD7084P All channel antenna.
For reception of ,
W02AT-D VHF low band channel 02 , WSPA , CBS and MeTv.
W08BF-D VHF high band channel 08 , WSPA , CBS and MeTv.
WCYB-TV VHF low band channel 05 , NBC and The CW.
W31DI-D UHF channel 31 , PBS.
W09AS VHF high band channel 09 , WYFF , NBC and This Tv.
WLOS VHF high band channel 13 , ABC and MyNetwork.
______________
Install a Winegard , LNA-200 'Boost' XT amplifier.
______________
______________
Use the 5 foot tripod antenna mount. ronard(911).
Use the , ronard(4560) eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www.solidsignal.com , or buy from , http://www.ronard.com.
________________
Here are some places to buy antennas and etc.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.google.com.
http://www.yahoo.com.
____________________
When using a rotator to turn the antenna , the Tv Must Be Capable of , Add/Scan channels , aka , Scan/Add channels , or , Direct entry of the Real channel number.
So the the channels can be put into the tuner memory with out deleting channels that were scaned before.
The tvfool channel list shows the Real Channel that is transmitted and received and the , virtual number.
______________________
