The antenna came in yesterday. I went and bought a 10' pole and set it on peak of roof with a tripod mount. I measured the height of antenna and im 26' from the ground. I have been messing with pointing it at different degrees and placing it at different locations on the peak for two days to get the most channels. It's not fun when your bye yourself. I think I wore out my ladder going back and forth from the roof to the LR TV. If I point it at 224 degrees I loose cbs 13.1, 13.2. 15, 15.2 but I gain 11 and 8 which are local advertising beach channels. I think it's the large trees and the opposite directions of the towers. Pointing the antenna at 350 degrees I get 32, 32.2, 32.3. 23.1, 23.2, 23.3. 15, 152. 21.1 , 13.1 , 13.2. I never could get 7 at either direction. I think im going to buy that amp you suggested before I lagg it down and play with the direction some more before I put holes in the roof.
