Old 26-Sep-2013, 4:23 AM   #24
skatingrocker17
Originally Posted by estefan2020 View Post
choose a LNA low noise amplifier, usually 1db or less
An amplifier by its definition creates noise, Read on discrete transistor amplifiers, but thats not all, An amplifier will amplify signal, as well as general noise in the environment + its own noise it makes.
If at all possible use an antenna with gain over a standard quarter wave antenna. Use a low noise amp/pre-amp at the antenna mast, only if you have +50ft of coax transmission line. quad rg-6 is not bad, RG-11/ is better, and is better than the standard dual shielding rg-6, but there are even better cable, but will drive the cost up considerably and not available in traditional stores, but is used in new home construction. each 100ft of coax will reduce your signal, This is why you have an antenna mounted low noise amplifier, to compensate for cable losses.
amplifying the signal at the tv/ fm tuner will will amplify an already degraded signal. Each splitter will reduce the signal, so a 3 way splitter will add insertion loss plus have 0.33 1/3 of the signal. Using the correct duplexer which has a hi pass filter for uhf tv , and a low pass filter for fm radio, then split the fm for the 2 fm receivers having 0.5 or 1/2 if the signal, More signal for the receivers, instead of using the traditional 3 way splitter.
You could try with a low noise amplifier at the antenna, and go from there. and swap the 3 way with a duplexer and a 2way splitter, if the signal level is not to your liking.
http://en.wikipedia.org/wiki/Coaxial_cable great read explaines cable selections.
Its easy to loose signal, but ones its lost, the quality will suffer if amplified after the fact.
Right now I just have a 50 foot run of RG6 coax to the radio.
In the next few days, I will have 25 feet of quad sheild RG6 from the antenna to a Channel Master 3414 distribution amplifier. The noise rating on the distribution amps seem to be VERY similar to the pre-amps. Usually a little under 3db.
skatingrocker17 is offline   Reply With Quote
