Old 25-Sep-2013, 11:45 PM   #2
Given that the obstructing terrain is closer to you in the San Fransisco direction, I suspect you would find it easier to go for the Sacramento market. This is a rare case where I would consider using a rotator, especially if the antenna was mounted in a way that makes aim adjustments challenging.
An ANT-751 would get some reception but I don't think it's not enough antenna. I think you would have problems with reception reliability on many channels. You need to consider going to the Winegard HD7698P. An RCA TVPRAMP1R preamp would be a good option.
I have no shame using the Antennas Direct 91XG and Antennacraft Y10713 in conditions with significantly better signal conditions.
