Old 25-Sep-2013, 9:53 PM   #3
The Current Broadcast Tv stations channels that are transmitted and received in the , USA , Canada , Mexico , are ,
UHF band channels 14 thru 51.
Your location has receivable broadcast Tv channels in All 3 Tv Bands.
The reception signal strengths of the Tv stations/channels at your location are , Low Signal Strengths and far away 65 plus + miles.
Install a Large ALL Channel Broadcast Tv Antenna above the roof in such a manner that the roof and building are not impeding and obstructing and blocking reception in the direction of , East.
Install a Winegard HD7084P antenna aimed at about 104 degree magnetic compass direction.
_____
Install a Winegard , LNA-200 'Boost' XT amplifier.
_____
Buy the HFS splitters at , http://www.saolidsignal.com.
______
Here are some strong and sturdy antenna mounts.
Use the (ronard911) 5 foot tripod antenna mount.
Use the (ronard 4560) eave antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www.solidsignal.com or buy from http://www.ronard.com.
_________
http://www.solidsignal.com.
http://www.amazon.com.
______
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast Tv reception and so do buildings and other obstructions in the directions of reception including your own roof and house.
The Best Practice is to install a antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
______
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.wchstv.com/DoubleReScanAlert.pdf.
