Old 25-Sep-2013, 6:22 PM   #1
Daffyca10
Why does my older Toshiba DLP constantly need rescan?
I have great reception with my new Clearstream 2 antenna (professionally mounted, very secure) but every other day my Toshiba TV says "auto scan required", at which point I need to unplug the TV, wait, and rescan and channels are back. I usually don't need to do a double rescan where I unplug the antenna signal from the back, just an unplug will do it. If I just rescan without unplugging, it says 0 digital channels. Since I have to do this so often I bought a powerstrip and have it next to the TV and whenever I have to do a rescan I just power off the powerstrip, rather than having to get at the outlet.
The one non-DTV channel that broadcasts here (SF bay area) - a music station on channel 5- never goes away from the scan even if you unplug the antenna cable completely. This is purely a broadcast DTV issue.
Anyway, my TV is fairly old by HDTV standards, a Toshiba 42HM66. Could the constant rescanning be eliminated with a newer TV? Usually the TV itself is not the issue with reception, I know.
thanks!
Daffyca10 is offline   Reply With Quote
