Old 23-Sep-2013, 11:44 AM   #6
couloir007
You need all the gain you can get. The C490 is a good antenna, but comes up short in UHF performance when compared to the 91XG.
The RCA TVPRAMP1R is a good amplifier when you want to combine a UHF and VHF antenna. The Antennas Direct PA-18 is a very good weak signal amplifier with a very impressive noise figure (lower is better). You would need a separate UHF/VHF combiner though.
I'm sticking with my first suggestion.
I'm within the UHF mileage of the c490, I'll give it a try, and if it doesn't work, return it. If it works, it can save me a bit of money. Thanks!
couloir007 is offline   Reply With Quote
