Tune to a working channel. Disconnect the coax from the tuner. What doses the tuner display on your screen? If it's the same or similar 'floating' message, you may have a problem locally. (Reconnect your antenna coax.) The goal of this exercise is to determine whether the 'floating' error message is originating in your tuner or is it being broadcast by the station.
Try a full rescan of the converter.
If the tuner reacts much differently than what you have been seeing when tuned to WLNY, contact the WLNY engineering department... Their satellite receiver or ATSC multiplexer may be having trouble.
Here in the NW, KVOS often has "Magnavox" 'floating' across the screen on their VC 12-3. I presume it's due to the source being intermittent (not a 24/7 feed).
