Old 21-Sep-2013, 9:25 PM   #9
No static at all
No static at all's Avatar
Originally Posted by skatingrocker17 View Post
Are you saying connect each tuner to the antenna and don't split the signal? For example for 3 tuners, get 3 300-75ohm and run each line to the tuner?
No pre-amp? Even for 100' run? I can get away with only 2 tuners.
No, one coax cable from the antenna to the splitter.
You may end up needing a low gain distribution amp, but I would try without amplification first.
