Old 21-Sep-2013, 9:07 PM   #7
skatingrocker17
Originally Posted by No static at all View Post
Either antenna would be a good choice & will far exceed what you are getting now with the Stacker. The FM 6 is slightly better & can be easily modified for even better performance. You should run a separate cable from the antenna to the FM tuner(s)
Are you connecting the antenna to 3 FM tuners?
Are you saying connect each tuner to the antenna and don't split the signal? For example for 3 tuners, get 3 300-75ohm and run each line to the tuner?
No pre-amp? Even for 100' run? I can get away with only 2 tuners.
skatingrocker17 is offline   Reply With Quote
