Old 21-Sep-2013, 3:28 AM   #3
skatingrocker17
Originally Posted by No static at all View Post
Sounds like you are most interested in improving FM reception. Is that correct?
The performance of that Sony radio will simply blow away your car radio with the proper antenna. For the best FM performance, avoid any amplification (it is NOT necessary) & use a dedicated FM antenna. You will be amazed what that radio is capable of.
So a low band VHF or "FM antenna" would be more suitable? I do like have TV too, as a back up to the DirecTV. I could always put up another antenna since a dedicated FM antenna would be much smaller than a larger VHF/UHF antenna.
skatingrocker17 is offline   Reply With Quote
