Old 20-Sep-2013, 11:47 PM   #1
skatingrocker17
Which Pre-Amp to use?
I have the HD Stacker TV antenna currently mounted about 30 feet about the ground on my roof. I also have a rotor. Right now, I'm using the Winegard 8275 pre-amp connected to 1 TV and 2 FM radio Tuners. (have DirecTV so not super concerned about TV signals).
Some of the stations I like to listen to (Detroit 101.1 WRIF and Windsor 88.7 CIMX) are between 70-80 miles away. They almost always come in great in my car and 50% of the time come in good at my house.
I have a Sony F1HD FM radio tuner and always hows 3 bars of signal when using the pre-amp, even if it's fuzzy. Could the close FM stations be overloading the signals that are 70-80 miles away? I Winegard 8275 has 29dB of VHF gain which may be two much. Although, the signal is split 3 times and the run to the radio is the garage is about 100' of RG6.
I have no problem receiving my local Toledo TV stations. Should I move to a pre-amp with less gain such as the 8700?
Thanks
skatingrocker17 is offline   Reply With Quote
