Old 20-Sep-2013, 6:54 PM   #2
stvcmty
Originally Posted by 76 Phils View Post
Edit - Just wanted to clarify that the signal strength for the Fox affiliate is medium strength on the TV Fool map, but is very weak at our house. The antenna we're currently using barely picks it up, hence my second question.
I would take the antenna you have outside (with a long cable to the TV), to see if the WPMT signal is better outside. You could do the same with putting it in your attic to see if there is signal up there.
Do you know which WGAL you get? Is it the main signal on VHF 8 or is it the signal on UHF 49? If you are getting WGAL on Real 49, then your VHF situation is easier than it looks from the radar plot.
Do you get/need the programming from WGCB?
stvcmty is offline   Reply With Quote
