Would a ¾ wavelength section of 450 ohm lead perform the same impedance transformation as a ¼ wavelength section? If I could just use 450 ohm lead, it would simplify the harness construction.
I am not looking forward to soldering 300 ohm lead to 450 ohm lead. I have all the hardware to put the two 4400’s together, and I have all the wire to do it. Right now, I am just waiting on time to get the installed 4400 down, and to bolt the two of them together.
