I still lean toward an antenna that has both UHF and H-VHF capability designed into it intentionally.
If you opt for the CM-4228, I think there's a chance its incidental H-VHF performance would not be enough to receive real CH-12 & CH-13 reliably. If that turns out to be the case, you can add a separate H-VHF antenna though.
