Thread: Antenna help
Old 20-Sep-2013, 5:14 AM   #4
Rev
Thank you very much for your reply. I am not concerned with WTZT, so I will probably opt out of the second antenna.
Understanding that outdoors would be preferred...
If I mount the suggested UHF antenna in the attic *clear of all the metal surfaces,* is there a rule of thumb that can be used to tell if I need an amp? I ask because the cable run required to get my antenna on the other side of the duct work, etc. would be quite a bit longer than I have now. Also, I assume RG6 would be fine?
Thanks again.
Rev is offline   Reply With Quote
