Thread: Help!
Old 20-Sep-2013, 1:35 AM   #3
Above the roof in such a manner that the roof and building are not impeding and blocking reception to the , North East , East , install a Channel Master CM4228HD antenna aimed at about 57 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
__________
A Winegard DS3000 J pole type antenna mount works Ok with the CM4228HD antenna.
__________
Install a Winegard , LNA-100 'Boost' amplifier.
__________
http://www.solidsignal.com.
http://www.amazon.com.
___________
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' ~ 'Antenna Channels' in the Digital Tv Setup Menu.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 23-Sep-2013 at 9:40 PM. Reason: Clarify information and typos.
