Thread: direction
Old 20-Sep-2013, 12:38 AM   #3
A 1 antenna Solution to receive Many Digital Tv stations/channels.
Above the roof install a , Antenna Craft HBU44 antenna aimed at about 224 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
_____________
Many of the Tv stations are very close and very strong signal strength , recommed do not use any type or kind antenna system amplifier.
Recommend use a plain and simple 4 way splitter.
_____________
If WITV-DT VHF high band channel 7 - PBS , is weak signal strength , is received on all 4 Tv's then you are good to go.
If not then you can try a Channel Master CM3414 distribution amplifier.
_____________
http://www.solidsignal.com.
http://www.amazon.com.
http://www.channelmasterstore.com.
http://www.antennacraft.net.
http://www.ronard.com
_____________
Do not use any of the Satellite Tv passive and active devices such as and not limited to , multi-switches , multi-plexers , splitters , couplers , amplifiers , power injectors , power supplies , and etc. , must be Disconnected and Removed.
Yes it is Ok to use the satellite Tv coaxes and other coaxes that are in/on the building to get the antenna reception from point A to point B.
_____________
Here are some antenna mounts.
Use the , ronard(911) , 5 foot antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at solidsignal or buy from ronard.
_______________
Last edited by teleview; 20-Sep-2013 at 11:32 PM. Reason: Clarify information and typos.
