Old 19-Sep-2013, 7:02 PM   #4
Originally Posted by protivakid View Post
How does Fox 25 come in for you? I live 15 miles west of Worcester but can get ABC, NBC, & CBS Boston with perfect picture, however when I manually select Fox 25 and monitor signals there is not even a blip of a signal. The towers for all these stations seem to be in the same location so I can't figure out why FOX does not come in. FYI, I am using a Mohu Sky HD.
usually, that means the antenna needs to be moved. Single-channel dead spots are pretty common when using antennas that are broadly directional. You may need to try multiple locations in order to find one where everything will play nice.
