Yes, the ANT-751 covers both UHF and H-VHF real channels. The Leaf lacks meaningful support of real H-VHF reception.
Try running a cable (not longer than 50') from the ANT-751 to just one TV. Walk the antenna around, exploring for the best location and aim. The building you're in and those around you make it impossible to know what aim point or mounting location will produce the best results.
If your TV is like most, it may need to be rescanned each time you try a new location or aim. This can require a lot of patience. I believe it will pay off though.
Reason: clarification
