Thread: Antenna help
Old 18-Sep-2013, 10:33 PM   #2
Metal ducts near an antenna are a problem worth avoiding. Metal reflects signal and if close to the antenna, detunes it.
A well made 4-bay UHF antenna (Antennas Direct DB4e for example) mounted clear of obstructions (outdoors preferably) would be a very good option. You may need to add a second antenna to make WTZT reliable. An Antennacraft Y5713 is designed to receive real CH-7 through CH-13 would be my choice. You can combine the two antennas into a common cable by using a UHF/VHF combiner. The Antennas Direct EU385CF include the combiner and a weather proof housing.
