Old 18-Sep-2013, 9:43 PM   #2
I would keep it simple. Try a passive splitter first. If it works, you saved money and avoided adding a small amount of noise that might cause trouble with an already marginal signal.
If the added loss in cables and splitter causes you to loose reliable reception, then add a CM-3410 ahead of the passive splitter.
FWIW, the CM-3410, CM3414 and PCT-MA2-4P are all the same 15 dB gain amplifier. The multiple output port versions simply package a passive splitter in the same case. I like to maintain the flexibility of being able to change the splitter, so I opt for the single output model.
