If you can't get a lock on only one channel then it is possible there is another problem especially since you've tried more than one antenna. They may be having trouble with their signal. I ran into that problem with a station in my area a couple of years ago. The signal was weak and I could not get a lock on it because they were having trouble at the station. Another issue could be something in the atmosphere causing this problem.
Have you tried running a single coax cable to a single TV while using a pre amp? You should not even need a preamp to get CH. 35 since the signal is in Yellow on your chart.
I have used the HBU 55 and it is a great antenna. I was able to get a lock on signals with a Zero NM without a pre amp. I doubt the antenna is the problem. More likely you have multipath issues at your location and moving the antenna to another spot on the property may solve the problem unless there is a problem with the signal at the transmitter.
